Santa Clarita, Ca.
1) do the gears come off the shaft? I've got a couple of questionable teeth on one.
2) What threads into the the end of the intermediate shaft? It looks like the thread on my "plug" is stripped and I can't get it out (yes, I removed the "C" clip). |
The extension tube to the oil pump and you dont need to remove the circlip to take the extension off.
The gears come off the shaft, you really need to access the pet... Bruce |
Santa Clarita, Ca.
Bruce,
I've got a PET but it shows the the whole assembly and not seperate parts (illus. 103-15). I meant the other end of the shaft (outboard end). |
