What is the best way to clean aa engine case
I am rebuilding an early 356 engine for a Friend and there is a Lot of corrosion on the case.
Is bead or walnut blasting OK or is there a better way. Thanks Lorne M. |
Walnut shells might be ok but soda blasting would be the safest way to go due to the ability to wash the soda away. I wouldn't be able to sleep well knowing there had been beads in or around the engine.
Also have to say I don't have much experience with the 356. Hopefully someone that has done it will chime in. |
Send it to Ollies for ceramic tumble.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/351023-aluminum-901-05-engine-case-tumble-polished-perfection-defined.html |
Another satisfied custumer of Ollies here. I have the same case as pictured in the link and it is great.
Is the ceramic tumble just for aluminum cases or can it be done to magnesium cases?
Thanks Guys
| All times are GMT -8. The time now is 08:52 AM. |
