Question 3.2 engine - number 8 main bearing seal removal
Concerns 1986 3.2. I am in process of re-building afore-mentioned motor.
Does anybody have any tips about removing the seal from number 8 main bearing? Mine seems to be stuck fast in the body of the bearing and won't pry out. I am concerned with using too much force with say a screw-driver that I might damage the bearing body.
Any experiences to share? Thanks.
Old 10-17-2009, 02:08 PM
put it on a surface that gives you some height and face down you can pin punch the seal out with a hammer and punch.
You can also leave it slipped half off the crank and pry it out with a heavy screwdriver as the crank supports the bearing.
Couple ideas that I ve used.
Bruce
Old 10-17-2009, 05:00 PM
Ok thanks I'll try that
Old 10-18-2009, 12:47 AM
MBEngineering's Avatar
HI Higsy
put your bearing against the vice or the corner of something to take the seal out, use the slot in the side of the bearing to remove the seal.
support the bearing
or upright
put a screwdriver in the slot
and hit with a good weight hammer, to deform the back of the seal inwards, so as you can then get the end of the screwdriver end under the back of the seal to prise out,
with no damage to the bearing
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 10-18-2009, 02:08 AM
Hi Mike
Thanks for the excellent advice & great pics!
Cheers
Mark
Old 10-18-2009, 03:01 PM
