66mm short stroke crank alterations.
HI All, i have a 66mm crankshaft that has had the rod journals increased from 22 to 24mm to take the later rod size. Can i now only use the later rods with this crank or will the earlier rods also fit?
Old 11-04-2009, 03:09 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I asume you made the rod journal wider?
That means there is no factory rod that will fit your crank.
All of the production rods that will fit 24 mm wide journal will be too short for the 66 mm stroke.
You will have to have custom rods made.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-04-2009, 01:53 PM
