-   -   How to bore out plastic T stacks to S stacks (http://forums.pelicanparts.com/911-engine-rebuilding-forum/506745-how-bore-out-plastic-t-stacks-s-stacks.html)
HKZ Bob 10-24-2009 06:25 AM
Dear all
I have T Stacks and would like to bore the to S Stacks.
Question? Who has done this before?
Did you used a drill? Whas is working Ok in plastic? How many step did you do?
34mm 38mm?
Or did you used a exanding reamer?
I have a box column drill which I woud use for this operation.
BR
Bobhttp://forums.pelicanparts.com/uploa...1256390688.jpg
BURN-BROS 10-24-2009 09:55 AM
Hi Bob,
Here is a "T" stack that I bored out to "S" spec.
I machine them with a CNC mill so I get a smooth taper from 42 to 38
I use a very long/expensive custom ball-mill. The material cuts easily but I suspect a tapered reamer will not work well as you will have a great deal of cutter/material interface. It will most likely chatter violently and leave a poor finish. I am not sure what a box column drill is.
The Max I have machined a plastic stack is 46 at the top to 42mm on the bottom.
http://forums.pelicanparts.com/uploa...1256403321.jpg
HKZ Bob 10-24-2009 12:01 PM
Nice work,
how much would it be if you do such a work?
BR
Bob
HKZ Bob 10-29-2009 02:38 PM
bump
