HKZ Bob's Avatar
How to bore out plastic T stacks to S stacks
Dear all
I have T Stacks and would like to bore the to S Stacks.
Question? Who has done this before?
Did you used a drill? Whas is working Ok in plastic? How many step did you do?
34mm 38mm?
Or did you used a exanding reamer?
I have a box column drill which I woud use for this operation.
BR
Bob
Old 10-24-2009, 06:25 AM
BURN-BROS's Avatar
Hi Bob,
Here is a "T" stack that I bored out to "S" spec.
I machine them with a CNC mill so I get a smooth taper from 42 to 38
I use a very long/expensive custom ball-mill. The material cuts easily but I suspect a tapered reamer will not work well as you will have a great deal of cutter/material interface. It will most likely chatter violently and leave a poor finish. I am not sure what a box column drill is.
The Max I have machined a plastic stack is 46 at the top to 42mm on the bottom.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-24-2009, 09:55 AM
HKZ Bob's Avatar
Nice work,
how much would it be if you do such a work?
BR
Bob
Old 10-24-2009, 12:01 PM
HKZ Bob's Avatar
bump
Old 10-29-2009, 02:38 PM
