sbmackie's Avatar
JE pistons in original cylanders?
Can this be done, or do you need to get a differenct cylander to accept the JE pistons? Reason for asking: the cost differential between JE and Mahle.
Scott
Old 10-27-2009, 03:00 PM
3 restos WIP = psycho
kenikh's Avatar
Yes - JE pistons and Biral cylinders are fine, although you should tell your supplier what kind of cylinder you will run so they can optimize the piston clearances. Nickies are the best cylinder for JEs since the alloys are a perfect match and exspand identically.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-27-2009, 06:17 PM
304065's Avatar
Search here for the terms "jugs and slugs" for everything I know about this subject
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-27-2009, 06:39 PM
Wer bremst verliert
JohnJL's Avatar
I dont have a lot of knowledge on this, but 2 engine builds I did with these. 11:1 JE pistons in 3.0L cylinders naturally aspirated and 7:1 JE pistons in perfectbore 3.2 cylinders seeing 10psi supercharged 350hp.
Both work well.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-28-2009, 02:08 AM
I have heard that Porsche Mahle pistons wristpin is slightly offset while the JE piston wristpin is centered and not offset.
It may be hearsay, but I've heard this offset makes a difference in piston skirt wear or scuffing especially in a horizontally opposed boxer engines because of the effects of gravity, and downward thrust and connecting rod angle during the power stroke.
This is a different situation than the comparison of expansion rates between JE forged alloy pistons and different cylinders in an air cooled motor.
Old 10-28-2009, 09:57 AM
304065's Avatar
Here is some good information on piston pin offset:
Piston pin offset
'81 R65
Old 10-28-2009, 10:27 AM
