-   -   Bypass mod hole size, paging MBEngineering (http://forums.pelicanparts.com/911-engine-rebuilding-forum/507461-bypass-mod-hole-size-paging-mbengineering.html)
4sd911 10-27-2009 08:22 PM
Searching this site I came across this thread. MBEngineering suggests that the bypass mod hole needs to be a minimum hole size of 10mm, or "use a 10mm drill, any less will give you oil press' prob's." What kind of pressure problems are we talking about? I see the hole in my case measures about 9mm. A 3/8" (9.5mm) drill bit will not fit.
MBEngineering 10-28-2009 02:27 AM
HI 4sd911
PM sent
regards mike
