Certified User
billjam's Avatar
964 distributor belt timing
I am just putting a 964 twin distributor back together after fitting new belt and regreasing the bearings. (This is cross-posted here as well as the 964/993 forum as I'm not sure which will get best response.)
I have been following the detailed instructions as per these DIY instructions that I found on a search earlier today, however when you get to the part about fitting the belt and setting the timing between each shaft, they are a bit hard to follow.
What's the simple version on getting the two shafts in the correct relationship?
Also, this little bizzo fell out of the dizzy as I was dismantling it and I can't find a home for it. Got any ideas?
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 12-13-2009, 04:46 AM
