Danimal16's Avatar
Cam Ideas for a Street 2.5L SS
OK all,
Need some insight on cam selection for a 2.5L short stroke. Here is what I have so far:
66mm CW Crank;
2.2L "S" rods;
Carbs;
90mm Mahle Pistons and Cylinders
CR should be about 9.5 to 9.8
2.7 RS Stock Cylinder heads and valves
What would be a recommended cam for this application that will spend 90% of its time on the street.
Dan
Old 11-19-2009, 12:36 PM
BURN-BROS's Avatar
Which Mahle 90's ? 10.3-1 for the 70.4 mm stroke?
I'd probably stick with a Mod S cam.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-19-2009, 03:01 PM
Danimal16's Avatar
Yes this is the 10.3-1 90's.
Thanks for the recommendation.
Dan
Old 11-19-2009, 05:24 PM
Navin Johnson
TimT's Avatar
Dr-60
'69 911 GT-5
'75 914 GT-3
and others
Old 11-19-2009, 06:49 PM
"solex" grind. I have a 2.5 built up just like what you want to do. Great combination for the street.
Paul
Old 11-20-2009, 04:43 AM
