Cam Ideas for a Street 2.5L SS
OK all,
Need some insight on cam selection for a 2.5L short stroke. Here is what I have so far: 66mm CW Crank; 2.2L "S" rods; Carbs; 90mm Mahle Pistons and Cylinders CR should be about 9.5 to 9.8 2.7 RS Stock Cylinder heads and valves What would be a recommended cam for this application that will spend 90% of its time on the street. Thanks
Dan |
Which Mahle 90's ? 10.3-1 for the 70.4 mm stroke?
I'd probably stick with a Mod S cam.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Thanks for the recommendation.
Dan |
Navin Johnson
Dr-60
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
"solex" grind. I have a 2.5 built up just like what you want to do. Great combination for the street.
Paul |
