Black and Blue
Engine Thermostat O-ring Replacement: no gasket?
all, replaced the o-ring to the engine thermostat. Lubed it up real good with oil. Does this simply go back together without any gasket at the top? doesnt seem like it would seal all that great with just the o-ring.
Thanks,
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver Last edited by Kemo; 12-02-2009 at 08:52 AM.. Reason: cant spell cant type |
Just the oil ring and it only goes in one way.
Bruce |
Black and Blue
When I put it back in, i made note of the openings down in the case where I believe the oil would pass and lined up the thermostat accordingly. i didnt try it, but it seems you could install the thermostat 180 degrees out and really cause some problems.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
GAFB
The holes are offset such that it only goes in one way. No gasket.
Several BMWs |
One way only, as posted.
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
HI,
The life of an oil thermostat is not pleasant. Locked away down in the belly of your motor, it whiles away its life submerged in hot oil like a giant metal French fry. All of the heat and pressure can eventually wear out the oil thermostat's O-ring, which will cause big problems for the oil thermostat itself. For an OEM-grade replacement oil thermostat O-ring.. Thank you.. |
