robmog's Avatar
case stud installation
working on my rebuild.
when i sent my case out to be flattened and align bored the shop removed
various studs, like the Int shaft cover studs and tranny mount studs.
when reinstalling these, should i use red locktite?
thanks
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 12-11-2009, 06:44 AM
You dont want to locktite the bell housing because you pull them to set up the engine stand.
The intermediate shaft needs to be casesaved because it will pull out, be sure thats done.
Bruce
Old 12-11-2009, 12:37 PM
robmog's Avatar
bruce ,the case savers have been done.
i'm referring to the perimeter bolts and tranny mounts.
what you say about the mounts makes sense, although when i tore the engine down i used bronze bushings and some washers to use the tranny bolts to mount to my stand.
now i'm reassembling the engine, should i locktite the case studs ?
i will red locktite the head studs.
bob
1972 E pos
someday....
Old 12-11-2009, 01:29 PM
Perimeter bolts I would use blue, make them so they dont fall out. I never red locktite anything, but I have used a torch to undo what others have done.
Bruce
Old 12-13-2009, 01:15 PM
robmog's Avatar
Thanks, blue it is
Old 12-13-2009, 01:31 PM
