Whats my 3.6L in parts worth?
I recently had my 3.6L motor rebuilt (after spun rod) with SS cams, SWong chip, new rings, exhaust valves, springs, raceware rod bolts, plug wires. Re used pistons and cylinders (passed inspection). 300hp dyno. It spun a bearing after 3 track sessions and I dont have the money or patience/heart to rebuild again so I'm considering cashing out. It looks like it was caught early -- rods and crank getting examined now to verify damage but it looks minimal. I'm working on an exit strategy.
Whats the box of parts worth approximately?
1980 911SC Targa 3.6L
Old 08-09-2013, 08:34 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Give me a call. I might be a player for the parts. ?? I might also be able to help you work out a reasonable alternative.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-09-2013, 09:31 AM
Any time work better for you Henry? Thanks
Old 08-09-2013, 12:03 PM
Hi
Anytime between 8-4:00 tuesday through friday.
760-728-3062
Cheers
Henry
Henry Schmidt
Ph: 760-728-3062
Old 08-09-2013, 02:42 PM
