hydraulic tensioners
Hello everyone,first time I've posted on here.I know there are loads of articles about tensioners but I really could do with some help.I have a 1976 2.7 targa which has just been upgraded to hydraulic tensioners complete with new ramps and chains.So far so good but after she warmed up there was still a rattle.Not at tickover or with revs on but on the die down of the engine.Any thoughts would be gratefully received.
Old 03-12-2010, 11:32 AM
I had annoying ticking, especially when the engine was hot.
Drove me nut's.
Dismantled the whole motor, And pin pointed the problem.
My rocker arm bushings were very worn, some more then others, and
I had severe pitting on two cam lobes.
I could, re-create the tic, myself, by hand, just by wobbling the shaft in the rocker arm.
Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC
Suspected track car
Old 03-12-2010, 04:34 PM
Can you pin pint the location of the tick to the chain housing? Left or right? If it is coming from the chain housing are you sure that the ramps are seated on the studs properly, did you prime your tensioners before they were installed and are you sure they sre getting good oil pressure?
If you remove the covers check to ensure that the oil relief valve (nipple on the tensioner) is intact, I had one come apart on installation. The aftermarket tensioners are not as hearty as the original.
Also you could check to ensure that the chain follows the groove of the guides, if not your ramps aren't aligned properly.
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-12-2010, 04:54 PM
Packy's Avatar
Get a stethoscope and have a friend rev the engine while you move around listening to different parts of the motor. Check the valve covers for sure. Use a mechanic's stethoscope, obviously, they help quite a bit.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 03-12-2010, 07:58 PM
Thanks for the ideas guys unfortunately wont be able to look at it till Monday but when I find it I'll let you know what it is.
Old 03-13-2010, 05:46 AM
Just to close this one,it was a faulty NEW hydraulic tensioner.Replaced it and everything is now ok.Thanks to all for the help.
Old 04-04-2010, 07:16 AM
efhughes3's Avatar
Good to know you found it. Were you able to diagnose and repair while the engine was in the car?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-04-2010, 09:25 AM
Boy, sure hearing this story a lot lately. Brand new pressure tensioners that don't work. I guess I got lucky with mine.
Lindy
Old 04-05-2010, 06:26 AM
efhughes3's Avatar
All the more reason to put some safety collars inside the cylinders to avoid a full collapse.
Ed Hughes
2015 981 Cayman GTS
Old 04-05-2010, 07:45 AM
gtihop's Avatar
I did the safety collars on the pressure fed tensioners after having a new one fail. Was very easy to do and would recommend it.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 04-05-2010, 05:18 PM
