Smile 911 exhaust glowing red
Hi all,
I have a '79 911 SC , problem that I am experiencing is that the exhaust manifolds are glowing red hot after start up , am afraid to drive it until I can figure the problem out. Any help?
Old 01-06-2010, 03:18 AM
911 tweaks's Avatar
I would venture to guess...only a guess...your h/e's are about to fall apart, meaning, the metal is very thin OR your engine is running VERY lean which will cook the engine in real short order...
Good luck & keep us posted!!
Bob
I live for 911 tweaks...
Old 01-06-2010, 03:30 AM
What do you suggest I do? h/e ?meaning
Old 01-06-2010, 05:36 AM
tobluforu's Avatar
You should post this on the tech board, but do you have cats installed on the car?
Old 01-06-2010, 05:44 AM
Check the timing and make sure the advance is working properly. If not, it can get very hot very fast.
regards,
Phil
Old 01-06-2010, 08:43 AM
Crotchety Old Bastard
RarlyL8's Avatar
Check your timing, fuel mixture and fuel injectors, in that order. If all OK check the valves.
Old 01-06-2010, 09:13 AM
I'm here to cause trouble
jimbauman's Avatar
Do you have heat exchangers, or just headers? Catalytic converter? What exactly is glowing red? How much of it?
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 01-06-2010, 11:09 AM
Dead lean...6:1 odds..
Kind regards
Old 01-06-2010, 02:42 PM
DUK DUK is offline
DUK's Avatar
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 01-06-2010, 04:29 PM
Certified Porscheaholic
777joee's Avatar
I know what happened.........
I'll guess it runs but not real well and it happens after about a minute or so right? Well most of the books even the BENTLY Book had the timing wrong. 1978 make sure the plug wires are going the proper counter clockwise direction in the firing order.
I did it and my cat glowed red because it was burning all the extra gas. The motor was running OK but had low power then I saw this glow.......very scary. Then I went back to basics and double checked everything. Then it purred like a kitten..........WHEW!.........until I found the broken head studs..........only seven then it was time for a rebuild anyway.........
Dave Mitchell
Proud owner of "The Beast"
2010 Intermeccanica Speedster with 100% 1980 Porsche 3.0L power and suspension.
http://photobucket.com/IM-6build http://www.intermeccanica.com/
Old 01-06-2010, 06:31 PM
Hi All,
Thanks for the replies , to answer a few , there are no cats installed on engine , the heat exchangers get red hot after a minute or two, will check timing and let you all know, have to strip engine down in any case cos oil pours out of left bank into exhaust , any clues?
Old 01-07-2010, 10:58 PM
RichHawk's Avatar
Figure out and fix what is causing your red hot exhaust before you take the motor out, or else it will likely damage your new engine as well.
Richard
Old 01-10-2010, 07:47 PM
