pete-stevers's Avatar
964 distributor in a 3.0 sc motor??
Can a 964 twin plug distributor be used in a early 3.0 sc engine?
What mods must be done to accomplish this?
Old 01-23-2010, 12:43 PM
Not unless the distributor crank gear is replaced with a later one for CW operation.
SC's run CCW, 3.6 distributors run CW; therein lies the issue.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-23-2010, 03:33 PM
is there still an manual adjustment for advance and retard
is any other management sys needed?
what type of costs will I incure to do the change?
Old 01-24-2010, 10:25 AM
Yessir, I do modify the unit so it can be adjusted, however I set them up in a distributor machine so if its installed correctly, you won't need to make any adjustments. Install it at 10-12 degrees initial, and its all set for 26 degrees by 5K.
It can trigger MSD's, stock ignition boxes, or any EMS you choose.
E-mail me for pricing. You will need an SC distributor as a trigger donor.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-24-2010, 10:57 AM
Try not, Do or Do not
Henry Schmidt's Avatar
You could just install one of these.
With our distributor there is no need to change the drive gear (don't need to slit the case) and they are built to your exact specifications. We can even add a vacuum advance, something you can't do with any other twin plug distributor options.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-24-2010, 11:01 AM
gestalt1's Avatar
if you wnated to use a 964 distributer in an early sand cast aluminum case with a 66mm crank would you use a 2L distributer as a core? can the 964 distributer shaft be turned down to fit the smaller case bore or do you enlarge the case bore for the distributer?
thanks!
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 01-24-2010, 02:34 PM
thanks!
The 3.6 distributor's 30mm body would be turned down to 27mm and modified to clamp down in the early case. Not a simple job or cheap one, but doable.
This twin-plug alternative for an early engine would not be my choice: I'd be using a unit such as whats pictured above as there are several choices, depending on your budget.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-24-2010, 03:27 PM
thanks!
Back in 1992 we were one of the first companies to convert the 964 distributor for use in earlier engine. The first one was build for a 3.2 engine in a club raced version of Denise Aase's # 54 IMSA GTU. It worked but was never considered optimum.
We have since given up on the twin rotor design in favor of the Burn_Bros conversion distributor.
Because of the large number of vintage 2 liter race cars converting to twin plug, we developed the 2.0 Gen II distributor.
It uses all Bosch internals and housing for this conversion.
Henry Schmidt
Ph: 760-728-3062
Old 01-24-2010, 03:34 PM
Here is a 2.0 sand cast case that was bored and had the bracket added for a 30mm distributor.
We also added an MFI pump bracket
Henry Schmidt
Ph: 760-728-3062
Old 01-24-2010, 03:40 PM
