Mikes 3.5
How I spent my thursday morning.
Supertec built this 3.5 Motronic engine for Mike G last thursday while Mike watched and took these pictures. The car is an 88 3.2 Cabriolet. The engine has LN Nickies 100mm, JE piston 9.8:1 and DC Super Cup cams. http://forums.pelicanparts.com/uploa...1264090203.jpg http://forums.pelicanparts.com/uploa...1264090246.jpg http://forums.pelicanparts.com/uploa...1264090272.jpg http://forums.pelicanparts.com/uploa...1264090282.jpg http://forums.pelicanparts.com/uploa...1264090292.jpg http://forums.pelicanparts.com/uploa...1264090305.jpg http://forums.pelicanparts.com/uploa...1264090324.jpg http://forums.pelicanparts.com/uploa...1264090409.jpg |
http://forums.pelicanparts.com/uploa...1264092052.jpg
http://forums.pelicanparts.com/uploa...1264092067.jpg http://forums.pelicanparts.com/uploa...1264092109.jpg http://forums.pelicanparts.com/uploa...1264092124.jpg http://forums.pelicanparts.com/uploa...1264092138.jpg http://forums.pelicanparts.com/uploa...1264092154.jpg http://forums.pelicanparts.com/uploa...1264092167.jpg http://forums.pelicanparts.com/uploa...1264092184.jpg http://forums.pelicanparts.com/uploa...1264092199.jpg http://forums.pelicanparts.com/uploa...1264092214.jpg |
http://forums.pelicanparts.com/uploa...1264092269.jpg
http://forums.pelicanparts.com/uploa...1264092284.jpg http://forums.pelicanparts.com/uploa...1264092422.jpg 3:30 and Mike's off to catch his flight home.SmileWavySmileWavy |
Single or Dual Plug
Is that a single plug setup? The heads appear to have one spark plug.
Thanks for sharing.. cool looking!
Single plug
May I ask why you chose to go with a single plug setup in a 3.5L motor?
Thanks Mark |
Single plug
Thanks Mark |
Bang for the buck is almost silly. This a street cabriolet for heaven sake. |
Todays progress:
http://forums.pelicanparts.com/uploa...1264119383.jpg http://forums.pelicanparts.com/uploa...1264119396.jpg http://forums.pelicanparts.com/uploa...1264119409.jpg http://forums.pelicanparts.com/uploa...1264119421.jpg http://forums.pelicanparts.com/uploa...1264119434.jpg http://forums.pelicanparts.com/uploa...1264119446.jpg http://forums.pelicanparts.com/uploa...1264119458.jpg http://forums.pelicanparts.com/uploa...1264119475.jpg http://forums.pelicanparts.com/uploa...1264119494.jpg http://forums.pelicanparts.com/uploa...1264119510.jpg |
Very clean....nice work.....
Doyle |
going 3.5, was there any concerns around using the SSI's as distinct from a larger exhaust choice? I thought the SSI's were considered as a little to restrictive for a motor that size ?
In a perfect world a slightly larger primary might be desirable for higher end operation but for the purpose of this exercise, the SSI seems like the best compromise. |
Nice! All that gold plating makes it look like P-Diddy's engine! :D
JB |
very nice. Any HP and torque estimates ?
But the truth is, unless you're willing to change parts "you get what you've got". |
265- 300 Wow !. Regardless of what the final number is it will be strong motor and a great ride.
I have to admit though that I get confused with how successful these 3.4 and 3.5 upgrades are in increasing power from a 3.2. If a 3.6 with higher compression puts out 250 HP, i am always baffled that a base 3.2 upgraded to a 3.4 or 3.5 can exceed what a 3.6 puts out so easily? |
Better exhaust and better cams are the key as well as the higher RPMs achieved by these smaller engines.
BTW: that's 265 hp 300 ft/lb of torque |
| All times are GMT -8. The time now is 10:09 AM. |
