Porsche Crest How much power?
Hi. Can anybody help me? Just bought a 1977 911 S 2,7 (matching numbers) It was brought to Norway from California. This car has NO airpump or thermal reactors (removed?) How many Hp has this car got then. Is it now identical to the 175hp version?
It has also got the SSI exhaust (from pelicanparts), Dynomax superturbo muffler, MSD multiple spark discharge ignition, hi performance coil and KN air filter. Anybody?
Old 01-24-2010, 03:09 AM
You probably are in the 175HP range as its now a '74 spec engine.
The other modifications such as MSD, coil, K&N don't do anything for power and muffler won't help much unless the fuel mixture has been adjusted to suit.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-24-2010, 09:19 AM
Porsche Crest Thank you!
Thank you Steve. The SSi exhaust system, will that give any extra Hp? The insurancefirms here in Norway are very picky on getting the right numbers when insuring the car as a veteran (30+ years)
Old 01-29-2010, 09:43 AM
