Send a message via Yahoo to shnewberry
Recommendation for machine shop in San Diego
Can any of the San Diego Pelicans recommend a machine shop for a 911 3.2 engine?
I need new valve guides, a valve grind, checking clearances on Ps & Cs, cylinder hone and replacement of head studs.
Seth
1984 Carrera and about 150 ziplock baggies.
Old 02-07-2010, 02:49 PM
greg79s
Scott's Porsche
National City Ca.
Give them a Call.
Old 02-08-2010, 12:21 AM
Send a message via Yahoo to jjrowe
Motor Works in national city is a machine shop that can get your stuff done quickly and has pretty reasonable prices. Many local independent porsche shops use these guys.
Motor Works
If you want some advice as well I would take the work up to Supertec in fallbrook. Its a bit of a drive but if you have any questions about your motor build you can bounce them off Henry when you drop the stuff off.
Old 02-08-2010, 09:21 AM
