robmog's Avatar
deck height puzzler.
i had my mag case machined for my rebuild.
ollies provided 1mm cylinder gaskets.
also had my heads done.
when i measure deck height i get no deformation of the 3 mm solder bits.
i think the solder is moving away from the edge of the cylinder on compression.
how can i get an accurate measurement?
btw its a 72 e
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 02-05-2010, 04:15 PM
abit off center
cgarr's Avatar
Try some clay in there then you can measure it with the back side of a caliper.
______________________
Craig
G2Performance
Old 02-05-2010, 04:24 PM
robmog's Avatar
thanks craig that worked nicely.
bob
1972 E pos
someday....
Old 02-05-2010, 05:37 PM
