totle's Avatar
930 engine assemly - cylinder/cylinder head seal?
Hi,
I am in the process of putting the engine back again after new valve guide replacement.
On a 930 there is not any seal ring between the cylinder and cylinder head like the SC.
Are you guys using any seal, or are the cylinder/cylinder head just mounted dry (no sealant) ?
Old 03-02-2010, 05:41 AM
andrew15's Avatar
On the 3.3L half finned versions there are no sealing rings - just mounted clean and dry.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 03-02-2010, 07:12 AM
totle's Avatar
Regards,
Andrew M
Thanks Andrew :-)
Old 03-02-2010, 11:57 AM
andrew15's Avatar
Just to clarify - you still use the copper gasket on the base of the cylinder to set deck height
Old 03-02-2010, 12:35 PM
totle's Avatar
Yes, Andrew, That is already mounted.
Was just curious if someone used any form of lochtite or any other sealant between cylinder and head. :-)
Thanks for posting. Always good to check since this is my first 930 engine rebuild :-)
Old 03-02-2010, 02:34 PM
