-   -   Best Way to Compress the Chain Tensioner (http://forums.pelicanparts.com/911-engine-rebuilding-forum/529496-best-way-compress-chain-tensioner.html)
CarreraWSJT 03-05-2010 04:16 AM
I have searched the forum but there does not seem to be much on this topic other than to use a C clamp. Wayne's book does not cover it and the Bentley manual suggests Channelock pliers and a 3 mm pin. What is the best way to accomplish this task? The engine is from a 1987 Carrera.
Bill
Flat6pac 03-05-2010 05:09 AM
I put the tensioner in a vise and slowly turn it down. Once its bled, put an allen in it to hold it collapsed pin.
Bruce
CarreraWSJT 03-05-2010 05:15 AM
What about while it is still installed in the engine?
Bill
Geronimo '74 03-05-2010 05:16 AM
Pipe wrench, a big one, compress slowly.
Once it is compressed, remove at once.
Walt Fricke 03-05-2010 03:53 PM
Bill
When it is in the engine, just pull it out. Don't worry about compressing it at that point.
Then you can use a vise or other methods to compress it, stick a nail (long term) or allen or other small tool in the hole if you are about to put it back in.
Walt
CarreraWSJT 03-08-2010 04:03 AM
Got it.
Thank you all.
