-   -   Piston rings for J&E help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/530697-piston-rings-j-e-help.html)
snbush67 03-11-2010 06:22 PM
I received a set of rings from J&E with my pistons.
The top ring and the middle ring look exactly the same.
Shouldn't the middle ring be channeled or have a step in it?
The set was sealed and one package was labeled top, the other ones were stacked together however I see no difference between the top and middle rings.
Shane
cnavarro 03-12-2010 03:05 AM
Top and second rings are the same on the Goetze ringset that JE supplies with those pistons. Both are a top radial width of 0.167in and thickness of 1.5mm, iron, taper face, phosphate coated.
snbush67 03-12-2010 10:12 AM
Thank you sir !!!
I may have mixed one of the top rings in with the middle rings when I was checking end-gaps but if there is no difference I wont worry about it.
