loose nut behind wheel
Just split the case, is this a problem?
Not sure what happened here, but is this of big concern, should I have it welded up?
Main bearings and crank journals look good, should I still do the rod bearings since I'm in this far? ![]() ![]() ![]()
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
a.k.a. G-man
about that hole.. I have no clue how it could've happened.
I was looking at the pics of my teardown but that particular area is not in any of my pics.... I can have a look at my case tomorrow, it's not reassembled yet. There are some good engine rebuilders on this forum, they'll chime in, I'm sure I don't know if it is an absolute must to do the rod bearings as well, but I would do them just for good measure even if it was not necessary. Definitely if you plan to do some HP increasing upgrades. If you do, replace the rod bolts as well.
Сидеть, ложь, Переворачиваться |
Thanks.
From the looks of it, it appears that a tube was installed down the bottom of the thermostat hole, and that is where it broke thru the casing. I pluged the thermostat hole and blew compressed air through the oil pump end and filled the area with the break out with oil to see if I got any bubbles from it leaking, but it appears to be tight. I have a great aluminum welder friend that can weld it up just in case. PS the black in the hole is the actual tube, the pic makes it look like it is broken open into the oil gallery.
Try not, Do or Do not
If you want, you can seal it with Permatex Hysol epoxy. As for bearings: replace mains, rods bearings ( bolts and nuts) and intermediate bearings. Anything less is half assssed.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry. I refuse to do anything half assed, It's Full assed or nothing!
I'm very familiar with VW engines (I'm in the VW restoration parts Biz) I have a Turbo charged fuel injected 71 VW Convertible, but this is my first Porsche engine rebuild attempt, I bought this engine just to learn on, and like you said, I don't want to do anything half assed. I've been reading Wayne's book every night before bedtime!
I had a hole in the exact same location. Mine wasn't as big, but I think would have been had I not done a rebuild. I used JB Weld over my hole.
'82 SC 3.0L Targa, Chiffon/Brown “It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche |
They invented Playboy for that particular time. Sweet young things dancing in your head not torque values and cleaning solvents.
Married for 17years and 4 Kids, this is my escape!
Married three times, single now, no kids and she's my escape!
No, she doesn't play chess.
That would explain the divorces!
a.k.a. G-man
Damn Henry, nice lamp!!
Henry..... she's going to messup that chair. make sure you check for snail tracks.
That seems rather presumptuous not to mention judgmental.
Perhaps she's the reason I have time and incentive to give advice.
120 HP/Liter is all I ask
You sure know how to live Yoda, is there any reason you come to work at all?
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche |
Lamp? Where? I didn't see a lamp.......
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Once you're done producing everyone should enjoy the liberty of this great country. Life liberty and the pursuit of ...... what shall we call it? Happiness ![]() I'm thinking about building a hot rod or two. Just picked these up. What do you think? a mid engine flat six 29 hi boy on duce rails? ![]()
Yoda, now let me get this straight.
You go from home here: ![]() to here at work ![]() to find happiness? I think I would stay at home if it were me.
Rat rod? I fully expect to see one of those on a Friday night Cruising Grand in Escondido sometime in the near future.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Don't worry about that hole inside the case. It's normal like Henry said. I wouldn't put epoxy there either, it could break loose and cause problems. There is an equivalent hole on the outside of the case behind the oil cooler. This one you should fill with epoxy to prevent leaks. If the one inside the case leaks it won't matter.
-Andy
72 Carrera RS replica, Spec 911 racer |
Oh confused one: I travel not to find happiness, happiness seems to find me.
