MrPerkles's Avatar
Send a message via MSN to MrPerkles
Question C3 oil pressure sender
Hi Guys I have a fresh C3 rebuild that is showing crazy oil pressure.I have fitted a new oil pressure sender from an SC ,will this give a different reading to a C3 sender ? Maybe a stuck oil pressure relief valve ?
Here is the engine prior to a first map to sort some fueling issues
www.facebook.com/pages/Bournville-Frameworks
Old 03-25-2010, 03:11 PM
The SC and Carrera use 5 atmosphere sending units 911.606.135.00 while the C2 uses the 928 part but I dont know the amount of atmospheres it uses.
Bruce
Old 03-25-2010, 06:14 PM
MrPerkles's Avatar
thanks Bruce
anybody else ?
Old 03-26-2010, 05:07 AM
Bill Verburg's Avatar
I never had experience w/ the SC oil pressure senders but I did w/ the 964s which used 928.606.203.01 the 964 sender gives readings that are double what the original '76 C3 sender(911.613.571.01) gave
SC used
911.613.571.01 >'79 same as the one used on the C3s
and
911.606.213.00 '80>
I don't know what effect the later SC sender might have
Bill Verburg
Old 03-26-2010, 02:37 PM
MrPerkles's Avatar
cheers Bill
well I have run it in a little more tonight and changed the break in oil,the pressure has now settled down,so I guess I was faffing about nothing.
Thanks anyhow guys
Old 03-26-2010, 02:48 PM
The 76 sender is a 10 atmosphere sender because that is what the guage is, at least in my 76 Turbo.
I missed what c3 represented in the original post.
Bruce
Old 03-26-2010, 06:27 PM
