-   -   Engine Builders..I need help.. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/533362-engine-builders-i-need-help.html)
jhora 03-26-2010 05:44 PM
I am scratching my head on this one and need some help...
I have a stock 2.7 engine that I am transplanting into a 914-6...
all was fine until I installed the 901 type flywheel and found that the timing marks were off...
When the fan crank pulley is at TDC and the distributor is also at #1 cyl...the flywheel TDC mark is about 20 to 25 deg off....
when I rotate the flywheel to it's TDC the TDC mark on the fan pulley is about 20 to 25 deg off ATDC
What am I missing here???
Thanks for any help
Flat6pac 03-26-2010 06:23 PM
On the 914/6 timing is set with the light beaming down onto the flywheel and the marks come up to the 35 because the only timing in the day was for the 35degrees @6K. I would think that marking your own with a notch would be the answer providing all pulley and distributor are properly installed.
Its been since 1980 since I had a 914/6 and 1987 since I replaced a flywheel on one and remember possibly the early first 5 years wouldnt be marked because there was no reason to mark 911.
Just the thoughts,
Bruce
jhora 03-26-2010 09:45 PM
Thanks Bruce...
Yes this 914-6 flywheel has the TDC and the 35 deg mark...
it's just that they don't line up with the distributor and front fan pulley..
it's just crazy...:confused:
turbobrat930 03-26-2010 10:35 PM
Originally Posted by Lara (Post 5260332)
If you have a trusted local engine builder with experience in Fords, by all means use them. Because of the quirky nature of Ford engines, we don't recommend having someone - no matter how good - build a Ford engine without extensive Ford experience. Having someone you can hold accountable is very important. Ask around your local Ford/Shelby Club for references. A search on Club Cobra might also find someone close to your home.
you Sir, are smoking crack!!!! where is it mentioned that he is talking about a Ford engine????
You must be a bot....
914/6 03-27-2010 02:15 AM
2.0-2.2 crank bolts are indexed differently than 2.4-2.7 cranks in relation to TDC #1
You will have to make your own timing marks based on the front pulley
jhora 03-27-2010 06:07 AM
I was thinking that but didn't have the old 2.7 flywheel to confirm....
Thanks!
