jhora's Avatar
Engine Builders..I need help..
I am scratching my head on this one and need some help...
I have a stock 2.7 engine that I am transplanting into a 914-6...
all was fine until I installed the 901 type flywheel and found that the timing marks were off...
When the fan crank pulley is at TDC and the distributor is also at #1 cyl...the flywheel TDC mark is about 20 to 25 deg off....
when I rotate the flywheel to it's TDC the TDC mark on the fan pulley is about 20 to 25 deg off ATDC
What am I missing here???
Thanks for any help
John
Old 03-26-2010, 05:44 PM
On the 914/6 timing is set with the light beaming down onto the flywheel and the marks come up to the 35 because the only timing in the day was for the 35degrees @6K. I would think that marking your own with a notch would be the answer providing all pulley and distributor are properly installed.
Its been since 1980 since I had a 914/6 and 1987 since I replaced a flywheel on one and remember possibly the early first 5 years wouldnt be marked because there was no reason to mark 911.
Just the thoughts,
Bruce
Old 03-26-2010, 06:23 PM
jhora's Avatar
Thanks Bruce...
Yes this 914-6 flywheel has the TDC and the 35 deg mark...
it's just that they don't line up with the distributor and front fan pulley..
it's just crazy...
John
Old 03-26-2010, 09:45 PM
E-85 sippin drunk
turbobrat930's Avatar
Originally Posted by Lara View Post
If you have a trusted local engine builder with experience in Fords, by all means use them. Because of the quirky nature of Ford engines, we don't recommend having someone - no matter how good - build a Ford engine without extensive Ford experience. Having someone you can hold accountable is very important. Ask around your local Ford/Shelby Club for references. A search on Club Cobra might also find someone close to your home.
you Sir, are smoking crack!!!! where is it mentioned that he is talking about a Ford engine????
You must be a bot....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-26-2010, 10:35 PM
2.0-2.2 crank bolts are indexed differently than 2.4-2.7 cranks in relation to TDC #1
You will have to make your own timing marks based on the front pulley
Old 03-27-2010, 02:15 AM
jhora's Avatar
I was thinking that but didn't have the old 2.7 flywheel to confirm....
Thanks!
John
Old 03-27-2010, 06:07 AM
