Type of sealant to use?
what type of sealant would be used to seal a brass screw-in fuel pressure gauge into an aluminum fuel rail? My friend is having problems with it leaking. Thanks in advance. This is not a porsche project, but know there are very smart guys here.
1988 cab. Gone but not forgotten
2002 BMW 540i 6SP SOLD
2003 BMW M5
1978 MB 280 CE PROJECT (PAIN)
2004 HONDA ACCORD DD
Old 03-31-2010, 05:35 AM
abisel's Avatar
Are the threads on the gauge pipe threads? If so, use the teflon tape you can get a plumbing supply. Tighten the gauge snuggly, do not overtighten.
If the threads are are a machine thread, try using a copper crush washer.
Old 03-31-2010, 10:15 AM
sealant
Loctite 574 works well as a thread sealer
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 03-31-2010, 08:24 PM
