SC cams in a 73.5?
I have a set of 3 bearing SC grind cams on the shelf. How would they perform in a 2.4 CSI? Is it worth doing the change?
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
Hi Sigurd,
Those SC cams will build you a little more top end power in a 2.4T, at the expense of a little bottom end torque. I would likely not do this unless I installed closer ratio gearing.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve,
thanks, you just saved me some work!
