Sigurd's Avatar
SC cams in a 73.5?
I have a set of 3 bearing SC grind cams on the shelf. How would they perform in a 2.4 CSI? Is it worth doing the change?
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 04-03-2010, 02:33 PM
Hi Sigurd,
Those SC cams will build you a little more top end power in a 2.4T, at the expense of a little bottom end torque. I would likely not do this unless I installed closer ratio gearing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-03-2010, 02:42 PM
Sigurd's Avatar
Steve,
thanks, you just saved me some work!
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 04-03-2010, 02:55 PM
