2.7 rebuild
The engine is almost done, I was doing a piston to valve clearance check:
I get 1,1/2 turns on No.4 exhaust adjustment screw. Cams are 2.55 grind, pistons CIS, case and heads have been machined. Do I need to tear this side of the motor down ? Let me know what you think! |
The thread pitch is 1mm on the adjusting screw.
Bruce |
Understood, so the question is will I have a problem with 1.5 mm clearance on the exhaust valve?
| All times are GMT -8. The time now is 09:44 PM. |
