2.7 rebuild
The engine is almost done, I was doing a piston to valve clearance check:
I get 1,1/2 turns on No.4 exhaust adjustment screw.
Cams are 2.55 grind, pistons CIS, case and heads have been machined.
Do I need to tear this side of the motor down ?
Let me know what you think!
Old 04-11-2010, 11:47 AM
The thread pitch is 1mm on the adjusting screw.
Bruce
Old 04-13-2010, 12:46 PM
Understood, so the question is will I have a problem with 1.5 mm clearance on the exhaust valve?
Old 04-13-2010, 02:43 PM
