-   -   Need case bolt IDs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/537753-need-case-bolt-ids.html)
SchnellSchweitz 04-19-2010 08:41 PM
Need case bolt IDs
I would like to know what bolts, washers and nuts go in these three locations.
Thanks again in advance for your help.
http://forums.pelicanparts.com/uploa...1271734775.jpg
Eric J.
Walt Fricke 04-19-2010 09:28 PM
The left hand one should house a stud which is in the other case half. Same with the far right one.
I think the remaining hole has a corresponding hole on the other case half. So just use an M8x1.25 bolt of sufficient length, with a washer on each side and a nut. Length? Just measure. You should have something which will do the job in your nut and bolt box. I think the parts manual gives it as 45mm.
docrodg 04-20-2010 07:52 AM
what he said...
Nice job! that case is CLEAN. Also like the tape keeping things out of the pump. Good attention to detail there.
SchnellSchweitz 04-20-2010 03:39 PM
Oh... ya. Now I see how the other case bolts will go. So it looks like I just need 1 bolt, washers and nuts. Thanks for the help and thanks for the complement.
If you see any issues with what I've got there... feel free to speak up.
I'm planning to seal 'er up soon.
Thank you.
Eric J.
nocarrier 04-20-2010 04:49 PM
I cant tell but are the lock tabs for the oil pump nuts there?
tadd 04-20-2010 05:03 PM
Lock tabs are an abomination. If they are soft enough to bend, they will yield in service. All metal eliptical stop nut is far better. Just match grade cause a harder nut will act as a die :).
SchnellSchweitz 04-20-2010 05:09 PM
Yep... Lock nut tabs are in. Thanks for checking!
