valve covers gasket sealer?
I have a 2.7. I am replacing the valve covers after some work. Should I use gasket sealer on the new gaskets Thank for the help
Old 06-15-2010, 05:52 PM
Senior Advisor
James Brown's Avatar
Nope, dry. No need for sealer.
08 Cayenne Turbo
Old 06-15-2010, 06:17 PM
You'll hate yourself later if you use a sealer. There are better and worse gaskets for getting a good seal. The thick silicon gaskets are good as are the green gaskets with a silicon bead around them. The gray gaskets can work but are more likely to leak if your valve covers are warped at all.
-Andy
Old 06-16-2010, 12:24 PM
