Carrera Tensioner spacers (?)
I've been looking through previous threads on this topic and can't find a definitive answer whether carrera chain tensioner spacers are used on my model.
I can't remember if one goes at the location shown below or not. It seems like something should go in this location. This is an '82/3.0L http://forums.pelicanparts.com/uploa...1276740462.jpg Thanks in advance for your responses. Eric J. |
The spacers are only used when you have the early style "narrow" idler arms. The idler arms in your picture are the later style and don't require a spacer
Thank you!
when I assembled my engine I made spacers and installed because I didn't like the large fore and aft play - was on a 89 3.2 motor. I checked the play and spaced to still leave some remaining play. My memory is that the play was on the order of +/- 1-2mm or more. I was thinking the the chain would move forward and out of line during braking.
Here's what Supertec did the remedy the spacer issue. Full width bronze bushing.
http://forums.pelicanparts.com/uploa...1277051835.jpg http://forums.pelicanparts.com/uploa...1277051863.jpg http://forums.pelicanparts.com/uploa...1277054168.jpg |
Henry,
I like that solution, more bearing area and shimming. -Henry |
They are half the price as factory Carrera arms too. |
| All times are GMT -8. The time now is 10:15 AM. |
