Daviboy's Avatar
Rebuilding Mechanical Chain Tensioner
Guys I know I am going to take serious flak for asking this question. However I have about $4000 in to a rebuild and at this time do not have the funds for a Carrera tensioner upgrade kit (unless anyone wants to donate one to the cause) So my question is this has anyone rebuilt their mechanical tensioners and if so whats involved. Is it worth buying the Chain Tensioner Slip Prevention Collars if I go this route. I know I should really wait till I can afford the pressure fed.....
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 06-24-2010, 10:27 PM
Porsche used to sell a rebuild kit for chain tensioners. Not sure now, but it is/was a service procedure. Check the usual parts places.
It's pretty simple. Remove internal snap ring, remove parts, clean, install replacement parts, re-assemble, bleed tensioner, then reinstall.
Sherwood
Old 06-24-2010, 11:24 PM
Daviboy's Avatar
911pcars by bleed the tensioner do you mean once new parts installed fill the tensioner body with oil replace cap, snap ring then compress plunger bleeding oil through the side port?
Davy
03 996 C4S
Old 06-24-2010, 11:37 PM
Repair kit for tensioners 911-105-901-01
2 required.
andy
Old 06-24-2010, 11:43 PM
Daviboy's Avatar
ajwans they are NLA from host do you know anywhere else to buy them?
Davy
03 996 C4S
Old 06-24-2010, 11:55 PM
You cannot reassemble with oil in the body. Lightly lube, then reassemble. Submerge the tensioner in a container of clean engine oil, then work the piston/plunger up and down to expel all air. At this point, the piston/plunger will be rigid. Use a bench vise to slightly compress the plunger prior to installing in the engine.
Opps. I haven't done this for awhile. I recall there's a breather port on the side of the tensioner. Remove stopper bolt to bleed the tensioner. Reinstall the bolt while submerged.
If our host doesn't carry the rebuilding kit, try ******** or do a search on the internet.
Sherwood
Old 06-25-2010, 12:52 AM
I bought mine through partsquick.com which seem to be no longer in business,
shame, they were cheap.
I believe these are still available, just not through PP.
This site might help you:
::911 TENSIONERS::::
I also found a corkscrew handy for removing the inner
O-ring.
andy
Old 06-25-2010, 02:52 AM
Daviboy's Avatar
Just picked up two kits on e-bay for $40......thanks all and ajwans I found that site earlier it is most helpful
Davy
03 996 C4S
Old 06-25-2010, 03:38 AM
Tags
tensioners
