motor stopped running
I was wondering if I pulled spark plugs and remove rocker arms, if I have a timing/ valve problem this might show. The chain covers are off and chains seem to be tight. Motor will not turn over. I was driving the car when it died, no loud noises.
Old 06-28-2010, 11:18 AM
where are you?
What do you drive?
Do you have sufficient oil to keep the engine from locking up?
Bruce
Old 06-28-2010, 12:21 PM
I'm in Ut. Sorry not enough info. I have a 1973 911 2.4. Prev owner had some upgrades so I'm still checking model. All gauges looked ok and oil was up. I had pushed in clutch to down shift when it died. I pulled over and things looked ok. Car started and I got off Freeway, pushed in clutch and it died again. Rolled to a stop and it wouldn't turn over from there. Been sitting for 3 years and I finally have time to work on it.
Old 06-28-2010, 02:49 PM
When you say won't turn over, is the motor locked or just cranks and won't start?
Old 06-28-2010, 03:33 PM
Engine won't turn with wrench on crank. When the shop towed it the owner said it wouldn't turn over with a wrench either. Seems to be a reputable shop they have done some work I didn't have time for.
Old 06-29-2010, 08:11 AM
efhughes3's Avatar
It sounds like you may have a clutch problem. The way you described it, when you engaged the clutch, it killed the motor, and it sounds like it is bound up.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 06-29-2010, 07:39 PM
E Sully's Avatar
Ed,
According to his description, when he pushed in the clutch pedal and disengaged the clutch the engine died.
I would think it's time to drop the engine and transmission.
Ed
1973.5 T
Old 06-30-2010, 05:16 AM
