Arrow 1000 Mile Question
I am still in the process of break in on my rebuild, I just hit 1000 so I am going to re torque the heads and cam towers, check that the rockers haven't walked, adjust the valves, etc., then its on to fine tuning.
When I re tourqe the heads, should I back them all out a qaurter turn and then re touqe in sequence to spec?
Or should I just apply spec tourqe to each one in sequence?
Also anything else I should check for?
I have changed the oil three times, the latest oil is still clear, I am going to change it anyways.
Thanks,
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 07-08-2010, 10:28 PM
I just check the torque. I wouldn't back them off. You will disturb the fit of the heads on the cylinders if you back them off.
-Andy
Old 07-09-2010, 08:09 PM
Thanks Andy.
Old 07-10-2010, 10:02 AM
