Outlaw 911
Crank Pulley Bolt Stuck - HELP
Hey Pelicaners -
I am pulling apart my 3L 930 engine for a rebuild - and have run into an issue. I am down to the crank pulley and can not get the center bolt loosened.
I have tried a nice long breaker bar - 1ft.
I have tried a longer breaker bar - 2ft.
I have tried a longer breaker bar with a pipe extension - 4 ft.
I have tried my impact wrench.
Yes - I have a flywheel lock in place and am turning everything the right direction - I think.
Yes - I have done a few searches - but have not turned up anything.
Any suggestions?
Outlaw 911
Old 07-06-2010, 04:44 PM
peppy's Avatar
Outlaw if it is the same as a 3.2 then the back side of the bolt has (teeth) and it is a bear to get off.
I used an electric impact wrench and I had the crank out of the case.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 07-06-2010, 05:18 PM
I used a impact on it, cranking up the pressure. This loosened it up where I could get it off with a 3 ft breaker bar. It is right-hand threaded, so ccw is the direction you want to go.
Dave
Dave
'75 911s Coupe
Old 07-06-2010, 06:11 PM
I dont have enough volume and run into the problem occasionally. I split the case and take the crank to the tire store and a couple of hits on his gun, off it comes...
Bruce
Old 07-06-2010, 08:02 PM
Two Rivers's Avatar
Someone may have used lock tight on the threads.Heat it up to around three hundred. The heat will soften the lock tight.
Old 07-07-2010, 07:18 AM
Outlaw 911
She came off!!!!
Thanks for the guidance guys - I was able to get the pulley bolt out with limited drama.
I guess I scared it when I broke out the 4 ft cheater bar, and it came right out.
Cracked the case - what an ugly, stinky, dirty mess...but nothing broken - a good sign. Will start a new thread on the rebuild.
Outlaw 911
Old 07-09-2010, 07:15 AM
