Fitting 901.105.361.01
Guys,
This fitting feeds the cam housings from the sump. It has an orifice in it to prevent oil from frothing. During the turbo era, Porsche changed the orifice size to stop oil frothing. By reducing the orifice, idle oil pressure increased. Has anyone used the new PN in their engine and what results have you had? Thanks Dom
dom toni 911E |
Dom,
I just installed the cam oil line restrictors in my 74 911S along with the pressure fed tensioners. Gave me approx. 10-15 PSI increase in overal engine oil pressure. Glen Pettigrew
1974 911 |
Thanks Glen,
Dom
dom toni 911E |
Max Sluiter
I would not use them in my engine. The increased pressure on the gauge makes you feel good but just masks any problems with low oil pressure- worn bearings, etc.
Oil restricrors revisit cam oil line Restrictor/Adapter Anyone used the oil restrictors ?? Cam tower restrictors - Good for break in?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Danke Flieger.
dom toni 911E |
Max Sluiter
Another thread from the Turbo board. Thoughts on oil restrictors
Try not, Do or Do not
We use them on every engine we build and have zero negative feed back.
Most negative impressions are based in theory not actual use. Perhaps 200 engine built by Supertec that all used cam feed restrictors. Every 3.6 based Porsche engine has restricted oil feed to the cam towers when flow rates are compared to earlier engines. We made cam feed restrictors back in the mid 80s some 5 or 6 years prior to Porsche installing them on the 91-92 Turbo engines. These restrictors were used on race, turbo and street engines some of which have been documented at over 240,000 miles. We warranty every engine we build and see no reason to change after twenty plus years of use. YMMV
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks guys, the restrictors are for use in normally aspirated engines, a 2.0E and a 2,7 RS. As Henry noted, I don't think there should be a problem.
Best to all Dom
dom toni 911E |
