-   -   Problem with late sprocket support (http://forums.pelicanparts.com/911-engine-rebuilding-forum/551574-problem-late-sprocket-support.html)
HKZ Bob 07-05-2010 11:40 AM
Dear folks,
I have a problem using late sprocket supports with second generation chain tensioners. ( J just rebuild them)
I used the late sprocket support because they were much better condition that my original ones.
Now I realize that they are thicker and not allowing me to use Chain Tensioner Slip Prevention Collars. ( Too less clearance)
What is my option to not equipped the collars or grinding the blimp down. Is the blimp hardened.
I don't want to change to the feeded tensioners.
Thank you for your advice.
Here some pictures
http://forums.pelicanparts.com/uploa...1278354898.jpg
http://forums.pelicanparts.com/uploa...1278354927.jpg
http://forums.pelicanparts.com/uploa...1278354972.jpg
http://forums.pelicanparts.com/uploa...1278355025.jpg
304065 07-06-2010 06:44 AM
Until the chains stretch, you won't be able to get the collars on, most people operate without them for a few thousand miles, then the chains have stretched (worn, actually) enough to get them to fit.
