HKZ Bob's Avatar
Problem with late sprocket support
Dear folks,
I have a problem using late sprocket supports with second generation chain tensioners. ( J just rebuild them)
I used the late sprocket support because they were much better condition that my original ones.
Now I realize that they are thicker and not allowing me to use Chain Tensioner Slip Prevention Collars. ( Too less clearance)
What is my option to not equipped the collars or grinding the blimp down. Is the blimp hardened.
I don't want to change to the feeded tensioners.
Thank you for your advice.
Here some pictures
Old 07-05-2010, 11:40 AM
304065's Avatar
Until the chains stretch, you won't be able to get the collars on, most people operate without them for a few thousand miles, then the chains have stretched (worn, actually) enough to get them to fit.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-06-2010, 06:44 AM
