HKZ Bob's Avatar
Where to buy Glyco Rocker Arm bearings
Dear All,
I am looking for a store who has this rocker arm bearing in stock.
Glyco is out of stock,
A new batch in planned for November 2011.
RB/KB
17,989 / 18.000 mm inner
20,000 / 20.013 mm outer
width 25.50 mm
Material Glyco 46 Semi
Order no. 56/2698
BR
Bob
Old 07-09-2010, 07:04 AM
abit off center
cgarr's Avatar
I had a set of rockers come in to be rebuilt and it had a replacement bushing in it but I dont think you can get them anymore. The part number on it was 930 105 341 00
______________________
Craig
G2Performance
Old 07-09-2010, 10:52 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Glyco may be what you're looking for in terms of original replacement type. But there's better options out there. Ask Craig a bit about his use of steel-bronze-teflon-lead bushings
Kevin L
'86 Carrera "Larry"
Old 07-09-2010, 11:06 AM
3 restos WIP = psycho
kenikh's Avatar
+1 on Craig's solution...mo betta than Glyco.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-09-2010, 11:24 AM
HKZ Bob's Avatar
Craig who is this supplier JCG?????
Old 07-09-2010, 11:18 PM
HKZ Bob's Avatar
Hello Craig,
is that your choice which you would use?
Item # Nominal Size I.D. Nominal Size O.D. Recommended Housing Bore Min. Recommended Housing Bore Max. Recommended Shaft Size Min. Recommended Shaft Size Max. Length
M1825BU 18 mm 20 mm 20.0000 mm 20.0210 mm 17.9660 mm 17.9840 mm 25 mm
BR
Bob
Old 07-09-2010, 11:50 PM
