carrillo 964 rods on 3.2/3.3
Just bought a set of carrillo rods believing the 3.2/3.3 was the same as 964.
I see now there are different piston end width on carrillo 3.2/3.3 and 964 rods. http://www.cp-carrillo.com/LinkClick.aspx?fileticket=0ZjqsBL%2b%2biI%3d&tabid=82 My rods are for 964 and I have a 3.3 with a 964 crank. Is this Ok? |
964 rods
The 3.2 thru 964 rod has the same dimensions, the 993 has narrower dimensions, I have a set of Carrillo rods here now and they are the same as a set of stock 964 rods, I looked at the carrillo page and I believe there is a mistake, as it shows the small end being the same width as the 993
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
the rods messures the same as the catalog for the 964....
looks like the 964 rods has wider main bearing end than 993 and 3.3 has wider piston end than 964... |
964
The 964 rods I have here are the same as a 3.3 rod & 3.2, I will call carrillo
Mike Bruns
3.2, 3,3 and the 964 rods are the same cast part number.
Bruce |
Yes, factory Porsche rods
Bruce |
Manassas, VA
I found that casting numbers can be misleading. Remember, those numbers come from the mold. What the machinists do to the rough castings (either CNC or manual) can be many variations of final dimensions.
Mark
1991 964 Polar Silver Metallic Turbo Coupe |
So will it be ok to use these rods in a 3.3???
listen to MBruns, yes you can use them
Great! Thanks!
-92 964 C4 - 79 930 "ruf" 380whp, K27, andial IC, Headers, electromotive hpv. - 88 "gt2" (project) |
