Vin-barrett's Avatar
how do you know if a 964 3.6 has the later cylinders with the gasket?
Is there an engine # cutoff that can be referenced or could it be as easy as the early metal intakes have no gaskets and the later plastic intake engines do?
-Vinny
1983 911SC
Old 08-05-2010, 11:05 AM
Question
ttt
-Vinny
1983 911SC
Old 08-12-2010, 11:54 AM
CaptainCalf's Avatar
Maybe this helps?
"There have been a few problems with the 964 engines that are worth mentioning. One is a cylinder head leakage problem on some of the earlier cars. The cars built in 1989 (K), 1990 (L), and 1991 (M) had the engines that are susceptible to a cylinder head to cylinder leaking problem. The early cars were those built up to 62 M 06836, M64.01 for the manual transmission cars and 62 M 52757, M64.02 for the Tiptronic cars. During the model year 1991 Porsche fitted their 964 engines with a modified cylinder and cylinder head gasket or seal. The original 964 engines did not have a head gasket and there has been some oil leakage at the joint between the head and the cylinder. The way that the original heads and cylinders were machined there was a small gap left out at the edge where the head studs were. Distortion of the heads caused by the head tourquing from the head studs was believed to be the source of this leak.
credit for the info: Engine & Transmission
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 08-12-2010, 12:40 PM
sure does.
Thanks Captain =)
-Vinny
1983 911SC
Old 08-12-2010, 01:25 PM
