-   -   Compression test... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/559299-compression-test.html)
JIM DRAGTEAM 08-17-2010 06:18 AM
Compression test...
Hello guys,
I would like to make a compession test on two 911 engines.
1) 1988 3.2 RoW
2) 1986 3.3 TBO RoW
What are the stock specs for them ?
Thank you for your time,
Jim
SmileWavy
E Sully 08-17-2010 11:09 AM
I can only tell you that on my freshly rebuilt US '86 3.2, after 1000 mile break-in, I have a consistant 185 lbs. on all cylinders.
Take your test with the engine up to temperature and post the numbers. I'm sure the experts will comment. Get a nice pair of gloves, engine and plugs are quite hot. Don't over tighten when reinstalling the plugs.
One of the important things is how consistant it is between the cylinders.
tom1394racing 08-18-2010 02:32 AM
Compression test results will depend on your ambient pressure and compression ratio.
Here's a table posted earlier on this forum with the results you should expect. The most important thing to look for is variation from one cylinder to the next. Should be less that 10%.
http://forums.pelicanparts.com/uploa...1282123896.jpg
WinRice 08-22-2010 10:05 AM
Info I've used before:
Puma Race Engines Technical Guide - Compression Tests
