Compression test...
Hello guys,
I would like to make a compession test on two 911 engines.
1) 1988 3.2 RoW
2) 1986 3.3 TBO RoW
What are the stock specs for them ?
Thank you for your time,
Jim
Old 08-17-2010, 06:18 AM
E Sully's Avatar
I can only tell you that on my freshly rebuilt US '86 3.2, after 1000 mile break-in, I have a consistant 185 lbs. on all cylinders.
Take your test with the engine up to temperature and post the numbers. I'm sure the experts will comment. Get a nice pair of gloves, engine and plugs are quite hot. Don't over tighten when reinstalling the plugs.
One of the important things is how consistant it is between the cylinders.
Ed
1973.5 T
Old 08-17-2010, 11:09 AM
Compression test results will depend on your ambient pressure and compression ratio.
Here's a table posted earlier on this forum with the results you should expect. The most important thing to look for is variation from one cylinder to the next. Should be less that 10%.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 08-18-2010, 02:32 AM
Info I've used before:
Puma Race Engines Technical Guide - Compression Tests
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 08-22-2010, 10:05 AM
