-   -   Parts cleaning (http://forums.pelicanparts.com/911-engine-rebuilding-forum/564887-parts-cleaning.html)
cmcfaul 09-17-2010 07:27 AM
Parts cleaning
My 2.4 911 E engine is in a zillion pieces in my garage. Parts should be arriving soon and the re-assembly process to begin. I am replacing a piston, all rings, heads rebuilt, chains, ramps etc. Just not splitting the case.
The pics I see of others doing similar rebuilds all look pristine. Mine is nearly as grimy as when I took it apart. For the shade tree mechanic, what is the recommended method, products and tools for cleaning parts both big and small.
Many Thanks!
Chris
73 911 E
turbobrat930 09-17-2010 08:50 AM
I would say, bar none, use just plain ole mineral spirits.... take a look at my rebuild post... of cousre, I hand polished mine...but it started by just using mineral spirits.. followed by a wash in dawn detergent and water.... dryed throughly after that... then a light coat of assy lube on the bearing surfaces, etc....
cmcfaul 09-17-2010 09:04 AM
Where do I get mineral spirits. Advanced Auto?
I have been using copious amounts of Gumout carb cleaner.
turbobrat930 09-17-2010 09:09 AM
home depot, lowes, and hardware store.... I live kinda close to a distribution center for an oil company.. I drove over there and brought with me a 5 gallon container.... it was about $2.50 a gallon... very cheap.... it will be close to $10 bucks a gallon at any of the above places..... but you wont use much more than that.. I was filling up my 30 gallon parts cleaning tank, so I bought more....
merbesfield 09-20-2010 12:08 AM
turbobrat930, I live in Atlanta and have been paying $6.00 per gallon from the paint store. Where did you find MS for $2.50? I would like to know for the next time I have to drain my parts cleaner.
JJ 911SC 09-20-2010 01:04 AM
Thanks for the MS tip. I wash my car with Dawn (green) its perfect; WARNING it does remove wax.
Back to oil stain part like Heat Exchanger I use this (safe on all metal) see the before and after pics at http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html
http://forums.pelicanparts.com/uploa...1284973438.jpg
haycait911 09-21-2010 01:12 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/434958-dishwasher-parts-washer-my-experiment.html
SchnellSchweitz 09-21-2010 02:47 PM
Here I am again with my WD-40 (No I do not sell this product). ;)
WD-40 is an amazing cleaner on serious oil build-up. It seems to blend with the existing oil on your parts and allows you to easily rub it off with a simple shop towel. Very little scrubbing compared to the other stuff I tried.
Eric J.
