arbita1's Avatar
Keep Pistons and Cylinders Togther
I know this has been asked. But I'm going to ask again. I'm pretty sure I have alusils. I can't find the KS but I see 10 fins and the piston skirt looks like they are. Plus the cylinders are not magnetic.
So do I keep them together or take them apart and measure.
Cars has 205,000 miles. Compression came out well across all cylinders. I'm not sure about burning oil because the engine leaked pretty good which was the reason for removal. I don't want to cause a problem that isn't there by separating them.
Thoughts.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-25-2016, 04:52 PM
theiceman's Avatar
i kept mine together it does make it tricky to get the wrist pins out then back in my oil consumption was great i was repairing studs i also have alusils.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 03-31-2016, 06:34 PM
what is the reasoning to keeping them together? if you re-ring them don't they reseat anyway?
1980 911SC Targa 3.6L
Old 04-01-2016, 07:17 AM
theiceman's Avatar
Well according to Waynes book alusils are one use only . I think there is likely hood of breaking rings if you replace them . There are people in various camps about this but since my performance was good and I had vey little oil consumption I left it all together and put it back all together. My personal choice.
Old 04-01-2016, 08:31 AM
TibetanT's Avatar
Keep the pistons inside the cylinders if you plan on re-using the set of Alusils.
That way you do not disturb the rings.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 04-01-2016, 11:35 AM
Engine rebuild..........
Matt(arbital),
Are you planning to re-use the old piston rings with 205-K miles? Why? I don't know a good reason why you should re-use them specially with the high mileage. This is your engine and you could do what you want but think twice. In case of doubt, contact John W. or Bruce A. and seek their opinion. These guys have done hundreds of engines while I just over a dozen. Keep us posted.
Tony
Old 04-01-2016, 01:14 PM
arbita1's Avatar
I ended up separating Pistons and cylinders so I can check and measure everything.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-01-2016, 02:18 PM
Matt,
Are you planning to re-use the 205-K miles old piston rings? This was the question people been asking you before and have not seen any response. Thanks.
Tony
Old 04-01-2016, 04:51 PM
gtihop's Avatar
i re-ringed mine about 9 years ago with Alusil. No problems to date after 35,000 miles.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 04-01-2016, 05:34 PM
Discseven's Avatar
Matt... This is a late comment given where you are but will say anyway. Before pulling heads, a leak down test of the cylinders can tell in advance where issues---if any---are in the cylinders. Worn rings / out of round cylinders can be heard hissing at the breather. Intake valves leaking can be heard at the intake manifold. Leaking exhaust valves at the exhaust pipe. Is nice info to have before diving in as it offers some insight to where a build is potentially headed.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 04-01-2016, 11:31 PM
arbita1's Avatar
Originally Posted by boyt911sc View Post
Matt,
Tony
I'm going to measure and see what happens. If the rings are worn I think I will go ahead and re-ring. John Walker gave me the correct part number for the Alusil rings. He said he does it.
I did not have a leak down test but I did do a compression test. All were close to 141 psi.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-02-2016, 05:15 AM
